OBD2 Mini Simulator
OBD, CAN, EV, RV
Postby eddy71ua » Sat Oct 02, 2010 12:00 am
Interestingly, someone brought this emulator and connected it with some diagnostic tools?
I soldered the emulator, the controller is flashing LEDs respond to pressing the "reset" but nothing else happens. I have tried 3 different adapters tested with cars - not one not connected with the emulator.
eddy71ua
Postby cyberofice » Fri Dec 31, 2010 12:00 am
I assemble one of my own and program the ATMEGA, what you do is turn on the LEDs in a determined manner which varies with the dip switch settings, but I connect it to modiag program and I get the following error: "no obd-diag interface found" and when I try to test it with the hyperterminal with elm-327 scanner set to iso-9141 protocol I get the following error: "init ... bus error". Anyone have any idea where will be the problem?
cyberofice
Postby etienne51 » Thu Jan 20, 2011 12:00 am
I have similar problems. I try to program the IC but I don't find right method. Where can I find the manual? Can anybody explain? I'll contact some Dutch people who have similar problems.
Greetings from Flanders
etienne51
Postby ferni » Sat May 07, 2011 12:00 am
Etienne51I have similar problems. I try to program the IC but I don't find right method. Where can I find the manual? Can anybody explain? I'll contact some Dutch people who have similar problems.
ferni
the unit not coming complete?
ferni
Postby danjerusmoke » Mon Aug 29, 2011 12:00 am
i too have having the same problem with the unit . i constructed the unit like the PDF ask. power the device up . and the 2 leds flash . flash twice with the green then the red . has anyone have solved the problem or got in contact with the company to find out what we are doing wrong?
danjerusmoke
danjerusmoke
Postby danjerusmoke » Fri Sep 02, 2011 12:00 am
well i just found out how the unit works . there's other software that you need from this site that will get the unit to work. the info you are looking for in on the info page. basically you have to reprogram the unit though the ISP port . there is a hex file that you need to flash to the unit you build and a second program that you need to edit the commands you would like to see in the 0bd2 scan device .
danjerusmoke
Re: OBD2 Mini Simulator
Postby zareimz » Fri Feb 23, 2018 2:07 pm
You may explain more
I have built this circuit 3 times, but it still does not work
Only the lights blink and the ELM327 does not connect to it .
I did the following:
1) I got the program atmega8 with the MINISIM.hex file
2) I made the board according to a schematic and I installed the pieces
3) I connected the voltage input to the 12 volt adapter and the output to an ELM327 device.
But the lights are flashing and the ELM327 can not be connected to minisim in any protocol (0 to 9).
Please advise if special work should be done.
Should I use MiniSimConfig to initialize it?
To use MiniSimConfig, should the SVR2 socket be directly connected to the COM port or use a programmer?
thanks for your answer
zareimz@Gmail.com
zareimz
Re:
Postby kimmysawi » Tue Jun 26, 2018 1:22 pm
ferni wrote:the unit not coming complete?
This was the best time to complete those situation and its on completing those words
kimmysawi
Re:
Postby lindabutts » Tue Nov 13, 2018 6:25 am
danjerusmoke wrote:i too have having the same problem with the unit . i constructed the unit like the PDF ask. power the device up . and the 2 leds flash . flash twice with the green then the red . has anyone have solved the problem or got in contact with the company to find out what we are doing wrong?danjerusmoke
Anyone have any idea where will be the problem? I have tried 3 different adapters tested with cars
lindabutts
Return to Automotive Electronics
