You may explain more
I have built this circuit 3 times, but it still does not work
Only the lights blink and the ELM327 does not connect to it .
I did the following:
1) I got the program atmega8 with the MINISIM.hex file
2) I made the board according to a schematic and I installed the pieces
3) I connected the voltage input to the 12 volt adapter and the output to an ELM327 device.
But the lights are flashing and the ELM327 can not be connected to minisim in any protocol (0 to 9).
Please advise if special work should be done.
Should I use MiniSimConfig to initialize it?
To use MiniSimConfig, should the SVR2 socket be directly connected to the COM port or use a programmer?
thanks for your answer
zareimz@Gmail.com
