Hello Pitbuell94,
I don`t think that your problem is related to the size of the SD card. I am using a 4GB SD card, which works.
When I connect the FPGA board to my Windows7 laptop, it also tries to install an Elektor FPGA Board driver, which it cannot find and apparently also does not even exsit, but that does not prevent my laptop from recognizing the SD card.
I suspect that your problem is related to formatting. How did you format the SD card? What operating system are you using (Windows 8 is not supported). Is the SD card recognized when you connect it to your PC directly (either in an SD card slot or with a USB card reader) and thereby confirm that the SD card is not defective? What is the type and brand name of the SD card?
Also, not sure if the DILIGENT board is compatible with the Elektor FPGA board when it comes to the Elektor article instructions, and there may well indeed be a size restriction for the SD card on that product. Please check with the manufacturer.
Regards,
Ag
