Bauen Sie Ihren Chip! Dezember 2012
Forum zum ELEKTOR-FPGA-Projekt
Postby ag » Mon Apr 08, 2013 12:00 am
Hello Pitbuell94,
I don`t think that your problem is related to the size of the SD card. I am using a 4GB SD card, which works.
When I connect the FPGA board to my Windows7 laptop, it also tries to install an Elektor FPGA Board driver, which it cannot find and apparently also does not even exsit, but that does not prevent my laptop from recognizing the SD card.
I suspect that your problem is related to formatting. How did you format the SD card? What operating system are you using (Windows 8 is not supported). Is the SD card recognized when you connect it to your PC directly (either in an SD card slot or with a USB card reader) and thereby confirm that the SD card is not defective? What is the type and brand name of the SD card?
Also, not sure if the DILIGENT board is compatible with the Elektor FPGA board when it comes to the Elektor article instructions, and there may well indeed be a size restriction for the SD card on that product. Please check with the manufacturer.
Regards,
Ag
Ag
ag
Ag
ag
Postby pitbuell94 » Mon Apr 08, 2013 12:00 am
Hi Dears Gentlemen,
Thanks a lot for all the information.
My Sd card is a TRANSCEND 2 GB.
By using an adaptor, I can see the SD card in my labtop.
I try your solutions.
ASAP it run, I'll go back to you.
Thank you very much again.
Fred ( Pitbuell94)
pitbuell94
Hi Ag,
I can put in the SD card some files so my card is not KO.
But now, I have an other problem.
The file generated by my XILINX ISE 13.1 is an BIT file and not a BIN file.
Size is all the timt the same => 166Kb
When I use my DIGILENT board, I only flash the BIT file generated by xilinx ISE.
I check again all the setting but it's all the time a BIT file.
Is-it possible someone just send me the correct CONFIG.BIN file?
Then, I'll put in true the SD card.
If the Led are blinking, I don't need to send back my board.
Vielen Danke Fur Eure HIlfe.
MfG.
(Sorry for the poor level of my German...)
Fred. (PITBUELL94).
pitbuell94
Postby klaus boda » Tue Apr 09, 2013 12:00 am
Hello pitbuell94,
This is a setting, when you implement your design.
At the Bitstream Options, first page:
"Process Properties - General Options" look at the third line:
-g Binary "Create Binary Config File" check the box
Then you get a file top.bin
This File has to be renamed to "config.bin" on your SD-Card, overwrite the eventually existing file.
I've attached you a top.bin to try.
Just rename it to config.bin.
Last but not least:
Your SD-Card has to be formatted in FAT32 (not NTFS)
Play a little bit with S1/S2 if the LEDs don't blink after about 5 seconds.
I tried the file a few minutes ago, it works fine, both LEDs are blinking in a different speed.
Greets!
[The extension bin has been deactivated and can no longer be displayed.]
klaus boda
Postby pitbuell94 » Tue Apr 09, 2013 12:00 am
Hi Kernspin,
Thanks a lot for this.
I try it soon and I send a feedback.
Fred.(Pitbuell94).
pitbuell94
Hi Kernspin,
Vielen Danke.
All is OK.
I think I need to check everything concerning my XILINX ISE.
Fred.(Pitbuell94).
pitbuell94
Hi Dears Madam und Monsieurs,
Now everything works fine.
I thank again everybody for the great support.
I have done one BIN file.
In attached file you'll find all code in VHDL for those who one to test in VHDL mode.
Now, my next project is to build and DIY Audio synth with 8 channels.
Part of code are already OK.
In this other post, you can see my video converter based on XILINX Spartan 3E 500Kgates.
It converts PAL video Color 625 lines to 819 B&W French old standart working on old Vaccum Tube TV.
http://www.vintage-radio.net/forum/showthread.php?t=62610&page=10
Fred.(Pitbuell94)
[The extension ucf has been deactivated and can no longer be displayed.]
[The extension vhd has been deactivated and can no longer be displayed.]
pitbuell94
Return to Rund um FPGAs
