Hi everyone,
First post, and a plea for help.
I have just been helping my daughter put together the bat detector kit currently on sale in the Elektor shop. We followed the debugging procedure in the manual, but it is exhibiting erratic behaviour. Symptoms are 9 time out of ten after switching on, it just emits a lot of white noise and the sensitivity of the microphone is almost nil. It appears that repeatedly switching it off and on again will occasionally get it into a correctly functioning state where there is very little noise and ultrasonic noises can be effectively tuned in.
What could be causing it to get into the bad state at power up? Once switched on, it doesn't ever appear to get out of this state. What should I be checking?
It's this one: http://www.elektor.com/bat-detector-kit-140259-91
The design looks like a superhet, using a 555 timer for a LO and a CD2003GB AM radio receiver chip for its mixer and AF filter. It has a one transistor preamp between an ultrasonic mic and the radio chip. I am assuming it is the radio chip that gets into a bad state, but am at a loss to know why this might be.
Many thanks!
