E-Wheelie: wheels and motors
OBD, CAN, EV, RV
Postby webby1234 » Sun Jul 19, 2009 12:00 am
I am looking forward to starting this project.
I am having problems finding suitable motors
and wheels any suggestions of suppliers out there?
Tony, UK
webby1234
Postby juggernos » Wed Aug 05, 2009 12:00 am
Can this kit be broken down and purchased piece by piece? So, I may be able to afford your genius. How about a set of prints?
juggernos
Postby thomas scherer » Sun Aug 09, 2009 12:00 am
At least the PCBs should present no problem if you want to make most parts yourself. The PCB artwork files can be downloaded here:
http://www.elektor.com/magazines/2009/july-047-august/elektorwheelie.984676.lynkx
and with
http://www.elektorpcbservice.com/
you should be able to get unstuffed pcbs. Sourcing the electronic components should be simple (RS, Digikey, Farnell etc.). For the motors have a look here, for example:
http://shop.mat-con.net/epages/62158737.sf/de_DE/?ObjectPath=/Shops/62158737/Products/my1020z2
Thomas
thomas scherer
Postby alec » Tue Oct 06, 2009 12:00 am
hi
i was contemplating using 250w motors instead of the 500w types ..i guess it will be slower but will there be stability issues does anyone think? or will the s/w make the necessary alterations for less torque.??
as i cant afford the wheelie kit and cannot get the boards populated/part kit i am going the zzaag route....
pity the elektor looks nicer..i think elektor have been rather over protective and petty with this project i hope someone produces a part kit soon..
alec
Postby thomas scherer » Wed Oct 07, 2009 12:00 am
Afaik 250W motors may have insufficient torque. Maybe it will work well enough for people <60kg
I don't know this but I do know: The only way to test it is to test it
The firmware needs not to be patched etc. for this, because the realised feedback loop will work with less and more powerful motors.
thomas scherer
Postby tomyang » Thu Dec 10, 2009 12:00 am
250W motors work fine, I have built my own self-balancing scooter by using two 24V/250W motors, which works fine. I can reach the maximum speed about 9 km/h.
tomyang
Return to Automotive Electronics
