Colinbus PCBBox
Colinbus PCBBox
Postby stevewidg » Fri Apr 21, 2017 12:54 pm
Hello All,
I have a PCBBox which is working on an OLD XP laptop which is on its last legs. I do not have a copy of the software, my stupid fault for not saving to a backup!!
Anyway I found this copy of software ( Norton said it was safe!!)
http://pcb-module.software.informer.com/download/
The machine I am trying to install on is W7 64 bit, I have tried installing in XP compatibility mode, and its installed in Programs(x86) folder. However the machine is not seen by software. As far as I can see it enumerates as an FTDI serial port, and I seem to have all the same name files from my XP machine, and although the software runs I cannot communicate.
Does anybody know if this software is ONLY 32 bit, or if there is something else stopping it working.
I saw someone asking about connector on back of PCBBOX, and this is a reply I got from then when they were still around, hope it might be useful to someone
Has anybody used MIPEC software? I tried the test version , but as it wouldnt output didnt want to buy, and they wouldnt provide a time limited full version.
Stevewidg
PCBBOX rear connector
stevewidg
Re: Colinbus PCBBox
Postby omaroski » Wed Jan 03, 2018 9:42 pm
Hey there,
don't know if you already fixed the issue with your machine, i have PCBBOX too and newest versions of PCB Module (138, 141 and 142). I've used the machine both on Windows 7 64bit than 32bit with no problem.
I also have some documentation about PCB Module and PCBBOX. If you are interested drop me a line so i can email you things i have. Somewhere i should have a latest version of the firmware too.
By the way, thanks for sharing the rear connector pinout!
Omar
omaroski
Re: Colinbus PCBBox
Postby BLF » Thu Dec 13, 2018 8:33 am
Hello everyone
I have a PCB BOX COLINBUS year 2013 . But I have no software to make it work. Is someone who owns these software and could provide it to me ?
Thanks in advance.
BLF
BLF
OMAROSKI
Postby BLF » Tue Dec 18, 2018 8:30 am
J'ai une PCB BOX mais je n'ai aucun logiciel pour la faire fonctionner. Est que vous pourriez partager avec moi votre documentation sur le PCB module la PCB BOX année 2013 et les logiciels.
BLF
BLF
Re: Colinbus PCBBox
Postby BLF » Tue Dec 18, 2018 6:49 pm
Est-que quelqu'un à utiliser la carte de pilotage : l'interpCNC V2 3 axes de SOPROLEC pour piloter la PCBBOX , si oui me montrer le schema de branchement pour la machine.
BLF
BLF
