The Elektor Forum will close. See also
this link. From Friday March 1st it is no longer possible to log in to the forum. However, the content of the forum will remain visible until the end of March. As of April 1st the forum will definitely go off the air.
HiFi, LoFi, Tubes, Transistors, ICs, Commercial, DIY
by assimaki » Tue Apr 13, 2010 12:00 am
It seems not possible to locate STW38NB20 or IRFB41N15.
I can get STW50NB20.
The STW50NB20 is recommended for TA3020 from the Tripath application note.
Can I use STW50NB20 for the ClariTy amp?
If yes, can I use up to+/-90V as described in the Tripath application note?
- Attachments
Tripath-TA3020.pdf
- (233.7 KiB) Downloaded 88 times
assimaki
by s soin » Sun Jun 12, 2011 12:00 am
Hi
Did you use the STW50NB20?
did you make any modifications to the amp and how is the performance?
I'm stuck at the moment as i cannot get the STW38NB20 fets.
Looking forward to your reply
Regards
SS
s soin
by assimaki » Mon Jun 13, 2011 12:00 am
STW50 is not the best alternative, I finally used STW34NB20 without any modification.
The sound is really good for a class T amp, much better than B & O icepower but is not at the level of a good valve amp.
Michalis
assimaki
Return to Audio & Video
