Hi,
I have been examining the Titan 2000 power amplifier (200w) in Build Your Own High End Audio Equipment book by Elektor.
The long tailed pair input consists if JFET's that are no longer available. The design is more than 10 years old, and the book does not specify the performance using the usual Audio Precision THD curve tracer.
Is it possible that the design could be revisited to improve, or provide the technical performance characteristics - such as power provided in 8ohm and 4ohm loads, as well as the THD curves ?.
Alternatively, i was willing to create the PCB's myself, but since the FET transistors are not available, can alternatives be suggested such as a dual FET device to ensure better component matching, or again a redesign of the amplifier to upgrade components that are now not available. Thanks.
Regards,
Richard.
{Originally posted in the wrong area}
