Filtres pour Klipsch Cornwall III
PostPosted: Thu Mar 08, 2018 5:34 pm
by Vicaire
i deleted my post, now it's in french, sorry....... :oops:
Re: Filtres pour Klipsch Cornwall III
PostPosted: Thu Mar 08, 2018 9:58 pm
by Vicaire
Remarquez, il y a aussi des gens qui proposent un filtrage minimum , est-ce que ça fonctionnerait ?????????? :o :o
PostPosted: Fri Mar 09, 2018 4:09 pm
by Vicaire
y a quelqu'un ????
PostPosted: Mon Mar 19, 2018 4:32 pm
by Crypto
Hello, I would like to improve my Cornwall III for more definition in the high and soft on the medium. For that I would like to modify my filter using Clarity Cap ESA reputed soft in the medium. Then for the high I think to use jantzen Superior ZCap, so performing in this register.
What do you think ? Thank :)
En français >>> Bonjour, je voudrais améliorer mes Cornwall III pour plus de définition dans l'aigu et de douceur sur le médium. Pour cela je voudrais modifier mon filtre en utilisant des ClarityCap ESA réputés doux dans le médium. Ensuite pour l'aigu je pense utiliser des Jantzen Superior ZCap, tellement performants dans ce registre.
Vous en pensez quoi ? :)
PostPosted: Fri Apr 06, 2018 5:53 pm
by Vicaire
Hello !!
my english is poor, sorry. :oops:
i'm watching about capacitors, in the Cornwall they are all in 250 Volts, but with different values ; 25 µF for the biggest to 1,75µF for the smallest. Seven capacitors.
But can we change these values ? I have some difficulties to find the EXACT VALUES !!! so i will ask to Francis Ibre, the boss...... ;)
Here you can see a great test : http://www.humblehomemadehifi.com/Cap.html (sob, the good are expansive!!)
I try on one Cornwall and see after if it's good or not.
