T-board test with atmega 328
The topic on number crunching
Postby Nixies » Fri Jan 30, 2015 9:43 pm
Hello,
I'have aquired the t-board recently and I have tried the first helloworld. The problème is that the clock, supposed to generate 1 second flashing led is not that accurate. I'm working without crystal, so I modified the commande F_CPU with the value 1000000 (this is the value which allows me to approach as much as possible to the second). If I compare the pace of this 1 second clock, it is slighly different than the one of my Watch. I don't understand why. I've tried it under linux (avr-gcc + avrdude) and Under Windows 7 but the result is the same, a second a bit longer than one second :?
Is it possible that the problem comes from the fact that I don't use any cristal ?
I've tried with a cristal of 4 MHz, modifying the F_CPU with 4000000 but it does not work, probably because I need to configure the fuse with external cristal, but I don't know how to do it :-(
Help from you should be really welcome :-)
Thank you very much.
Nixies
Nixies
Re: T-board test with atmega 328
Postby ag » Sat Jan 31, 2015 1:29 pm
Hi Nixies,
How much different?
According to the datasheet, the internal clock of the ATMega328 is 8 MHz, so I don't think you can improve the tolerance by using a 4 MHz external crystal.
The nice thing about the Arduino IDE is that beginners do not have to worry about setting fuses. I recommend you use the Arduino IDE until you have gained more experience.
Regards,
Ag
ag
Postby Nixies » Sat Jan 31, 2015 9:50 pm
Hello Ag,
To be honest I want to avoid Arduino, because I really want to understand what is Inside the µc.
Difficult to describe the difference, but if if want to make a clock with this kind of programme, it will quickly drift :-(
I modified the fuses by means of AVR Studio (Menu Tools -> Device programming) to use the 4 MHz Crystal, that's why change the F_CPU. In the meantime I read some docs and I saw that I did not use the good fuse option. I will try again. I let you know.
Ag, do you have the possibility to try this king of code ?
Anyway, thank you very much.
Nixies
Nixies
Postby ag » Sat Jan 31, 2015 10:24 pm
Hi Nixies,
I do not have a T-Board, but I do have an Arduino with a ATMega328 (Duemilanove), which is basically the same. So yes, I can test such code. That is why I wanted to know how far off your timing is running. Fuse settings are always a problem for beginners, but with reading the docs to find out how, you are going in the right direction. You might want to visit AVR Freaks at http://www.avrfreaks.net to get some good beginners tutorials and assistance. ;)
Regards and LoL,
Ag
ag
Postby Nixies » Sat Jan 31, 2015 10:45 pm
Thank you Ag for this link. I will take a look to it.
Speek to you later.
Regards,
Nixies
Nixies
Postby Nixies » Sun Feb 01, 2015 6:11 pm
I've tried with the second T-board, embedding a ATtiny 84, and the second is a second :D
I will try to search why it is not the same with the atmega328.
Nixies
Postby Nixies » Sat Feb 07, 2015 11:42 am
I changed the mega 328 and it is working.
Honestly I don't know why it did not work with the first one. Probably the fuses :(
Nixies
cron
