by fflinera » Mon Jul 06, 2009 12:00 am
I have tried to use TinyCAN View with the TinyCAN_I board of the paper, but it had been impossible.
I have done the installation process as it is defined in the article and is described by "ELEKTOR editor" in a previous post. No problems, Led lights as it is defined in the article. I have also installed GTK libraries succesfully.
When I run TinyCAN View, There is a problem. In the main window, "Start" "Can Reset" options are disabled. I suppose that the problem is with the driver. The article uses a USB-CAN driver file "mhstcan1.dll", but it is not included in the download files. Other call "mhstcan.dll" is the only one that I can found, but with this file the software is not working apropiattely in my PC.
I attach a file with some captured images and a more detailed description of my problem.
Moreover, in the figures 4 and 5 of the article, the text is english and, in the version that I installed the menus are a mix of German and Spanish.
Someone can clarify which is the problem?
Sincerely
- Attachments
tiny-problems.pdf
- (108.87 KiB) Downloaded 65 times
