Modulo D Amp
HiFi, LoFi, Tubes, Transistors, ICs, Commercial, DIY
Postby pj2br » Sat Apr 24, 2010 12:00 am
Dear Forum,
I completed the Modulo D Amp and it works. I am having trouble however, finding a RC5 compatible remote. I whent through several Universal Remotes without much luck. Any one of you have a woking remote and is willing the share the model number or code with me? Thanks in advance. Brett
pj2br
Postby anneo » Thu Apr 29, 2010 12:00 am
Why not look in the Dutch forum under,Audio,Modulo D met ?(and more)
Anne
anneo
Postby sarma » Sat May 01, 2010 12:00 am
PJ2BRDear Forum,
Philips TV remote is RC5 type, you might try one.
sarma
Postby anneo » Sat May 01, 2010 12:00 am
The MODULO D expects codes for a remote with an adress of 20.
That is NOT a TV zapper.
Anne
anneo
Postby alan2 » Sun Jan 23, 2011 12:00 am
I have an original Philips TV remote, but it does not work with the modulo D amp. I've wired pushbuttons to the spare processor inputs (PD0, PD1, PD2) so can control the amp that way. It would be good to get the remote working though.
I noted that the magazine article photos show the IR receiver mounted 180 degrees rotated, with its leads bent backwards. The silk screening on the board I bought from Elektor has he receiver facing the other way (window facing inwards toward the display). I've followed the PCB tracks and my device seems to be the right way round (agrees with the PCB silk-sctreen). That's always assuming the receiver supplied in the Elektor kit was the correct part. Has anyone else managed to make the IR control work?
alan2
Postby drv » Fri Sep 30, 2011 12:00 am
hi,
someone has the serigraphy? or a photo to the location of the components.
I'm going crazy to mount it.
thanks
drv
Postby sasqaz » Tue Oct 11, 2011 12:00 am
Hello,
I completed a Modulo D Amp and it works well. I haven't had any joy with the IR remote yet either and fitted some external switches to make it usable for the time being. What I really need are the fuse settings for programming the updated version of the software. I can't see it anywhere, although it was promised by the magazine text to be included in the zip file as an image? Any help greatly appreciated.
sasqaz
Return to Audio & Video
