Sorry for long break reply
First of all I checked IC5 and IC7 component and its around (+ -) 4.98 volts and then disconnected P1
It says Elektro 9/2002 like that
ESR Tester adjustment
Start with the voltmeter circuit.
P1 should be disconnected at this
point. Connect a known, accurate
voltage source of less than 200
mV to point TPA (test point A)
and adjust P5 until the LCD
shows the right value. Remove the voltage source. Connect TPA to TPB,
short the test leads together, and adjust
P2 for a ‘000.0’ reading. Remove the connection.
Reconnect P1.
Ok i set voltage source to 0.150 V and then connected to positive(red cable) crocodile connecter ESR Meter TPA (There are TPA and A labels!) and now which part should i connect negative (black cable) ? There is no GND label?
So I tried with negative crocodle connecter to A lable and then i read (1 .) open circuit i adjust P5 and then with without any idea other potentiometers P2,P3,P4 but no changes.it's still (1 -)
Last question do we need extra DMM for readings i'm looking only Esr Meter screen.
Thanks
