Platino Soldering station writing hex code
Equipment, circuits, projects, procedures
Postby ULfholt » Thu Jun 30, 2016 5:29 pm
I have nearly finished the project, but need to burn the hex code to a Atemega 328P chip. I have tried the following way:
Insert a new chip on an Arduino Uno.
Connect a USBTiny to the Arduino and connect the wire.
Run following command: avrdude -c usbtiny -p m328p -U flash:w:Platino_soldering_station.hex:i -U efuse:w:0xff:m -U hfuse:w:0xd9:m -U lfuse:w:0xe2:m
This seems to work well, but gives me the following error:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x07
avrdude: verification error; content mismatch
avrdude: safemode: efuse changed! Was ff, and is now 7
Would you like this fuse to be changed back? [y/n]
Can someone please tell me what I am doing wrong and how to fix this?
Best regards
Ulf
ULfholt
Re: Platino Soldering station writing hex code
Postby ULfholt » Fri Jul 01, 2016 8:16 am
Just an addon:
As far as I can see, only the 3 lowest bits in efuse are valid. The 5 upper bits are undefined/not used, so WHY would we want to set efuse to 0XFF? This will off course set the 3 lowest bits to 1, but so would the standard value, which is 0X7
Ulf
ULfholt
Return to Test & Measurement
