Debug ADC PIC microcontroller
The topic on number crunching
Postby mircea1981 » Sun Feb 12, 2017 8:09 pm
Hi.
I am a beginer in pic microcontroller and i need some help.
I have a development board from Microchip, PICDEM Mechatronics with a pic16f917 microcontroller.
I use MPLAB IDE v8.70 and HI-TECH ANSI C Compiler.
I try to make a program using the ADC.
How can i make debug ?
It is possible to see the result of ADC in real time ?
It is possible to see a waveform in MPLAB with the value of current on the ADC channel ?
Thank you in advance.
Best regards.
mircea1981
Re: Debug ADC PIC microcontroller
Postby jan.lichtenbelt » Fri Feb 17, 2017 3:18 pm
Dear mircea
There are two Forums who can help you:
1) http://www.microchip.com/forums/f238.aspx
2) http://www.matrixtsl.com/mmforums/index.php
This last one is an easy way to program your chip. The programm is free. But I'm afraid the ADC is an extension.
Kind regards
Jan Lichtenbelt
jan.lichtenbelt
Postby risc » Tue Oct 24, 2017 10:50 pm
Hi,
Please find herewith an archive with several projects for the PICDEM Mechatronics board using PIC16F917.
These examples use various resources on the board, LEDs, ADC, LCD, UART,...
You will need to install (all free) following SW :
MPLAB X v4.01 or later
XC8 v1.43 or later
Regards
Mechatronics_C.zip
C Examples for PICDEM Mechatronics
(396.58 KiB) Downloaded 41 times
risc
