maybe it could be interesting for some, just to know that it's possible
I installed the whole circuit in a metal box for shielding
The sensor I've put in an aluminium tube (from an alcohol marker) - and made the connection through a HQ power, shielded microphone cable - with the circuit.
I've cut of the top of the marker (side of the diode) and covered the top with 2 layers of aluminium mylar. Extremely thin, but expensive.. Positive side is that alpha's also get trough. (just for gamma's, normal aluminium foil will do)
And again all shields to ground - including the mylar
Works perfectly, and I think is easier to use for sample measurements.
