Note next time I will make a new thread for different topics
Apparently not, because now you ask a question about USB
In CD of course there are two files of Flowcode that does not match the course document USB slave and USB slave ad read.
Correct, these programs are not in use and should not be on the CD. This section was removed from the course before it was even published because it required knowledge (and possession) of VB. It was felt that this was outside the scope of the course, and would make it much too difficult for the students. So you can safely ignore these files on the CD.
Also I found that assignment 12f can not be made in we do not have VB
Yes you can, you dont need VB to answer the question. It is not a course on PC programming, so the question is just a small "extra". As the course states do not worry if you don't know the answer.
and the flowcode program is not in CD course.
Correct. The answer is given in the answers section, but not as an actual program.'
