Ultrasonic Directional Loudspeaker - March-2011
HiFi, LoFi, Tubes, Transistors, ICs, Commercial, DIY
Postby samdak » Tue Mar 15, 2011 12:00 am
Hi,
I had recently bought the Kit for "Ultrasonic directional speaker" that appeared in March-2011 Edition of Elektor, the kit comprises of parts for 1-Channel (though the driver PCB supports for 2-Channels) and the Ultrasonic Transducers Array (x50 piezoelectric transducers). With proper supply of 12v i am able to hear the directional sound produced by the driver kit, but not the music/audio when i have the audio jack connected to a stereo system.
Also i did observe that the MOSFET drivers IRF540 gets heated up very soon.
Not sure what's happening and why i am not able to hear the music/audio on the speakers.
Any suggestion/help is appreciated.
thanks
Sam
samdak
Postby yvonne » Sun Apr 17, 2011 12:00 am
LED lighting is a lamp or other light that uses
LEDs as a source of illumination. Most lighting comes from an incandescent or fluorescent light bulb. Different than the traditional bulb, LEDs can be put into traditional lamps and used like most other light bulbs. They are much more efficient than incandescent or fluorescent bulbs.
LED stands for light-emitting diode. That is, simply, a semiconductor device that converts electricity to light by using the movement of electrons. LEDs were invented in Russia in the 1920s. They were put into practical use in the United States in the 1960s by General Electric. In the late 1960s, Monsanto Corporation was the first to mass-produce LEDs, and Hewlett-Packard used them in its early calculators.
There are many consumer advantages to LEDs over incandescent or fluorescent light bulbs. LED lights consume much less energy. They are 300 percent more efficient than a compact fluorescent light (CFL), and 1,000 percent more efficient than an incandescent bulb. They have a very long life, about 50,000 hours of use at 70 percent of their original power. (LEDs don’t burn out or flicker, they simply fade.) This works out to eight hours a day for 13 years at 70 percent power. A typical 60-watt incandescent bulb may last about 1,000 hours.
LED lighting contains no mercury or other toxins. LEDs emit no ultra violet (UV) light, so they don’t attract bugs. They don’t generate heat, so they are cool to the touch. They don’t generate radio frequency waves, so they don’t interfere with radios or television broadcasts. They also are resistant to vibrations and shocks.
Tweet Abbreviation of light emitting diode, an electronic device that lights up when electricity is passed through it. LEDs are usually red. They are good for displaying images because they can be relatively small, and they do not burn out. However, they require more power than LCDs.'
yvonne
Postby -=db=- » Wed Oct 05, 2011 12:00 am
Hey,
I'd like to get a hold of that kit, who was the advertiser? I don't get the magazine so I can't look it up. If you can provide a web link, that would be great.
Did you get your problem resolved? How well does it work? Once I get my kit, if you need any help getting it working, let me know.
-=db=-
Postby Elektor Editor » Wed Oct 05, 2011 12:00 am
Have a look here
http://www.elektor.com/magazines/2011/march/ultrasonic-directive-speaker.1707039.lynkx?
You can download the article using the e-credits you got on registering to this website.
Jan
Elektor Editor
Return to Audio & Video
